https://cliqz.com/en/support/support-ende-windows-xp-und-vista
You can install the Cliqz extension for Firefox on ESR. Add HTTPS Everywhere and maybe an ad-blocker, and you’ll end up with a similar package as the Cliqz browser.
the above is from the link , read this and see if you can find the download
http://www.softoware.net/apps/download-cliqz-for-<b>windows</b>-xp-os.html
above has an even earlier version for xp
Cliqz is based on the Firefox browser. Firefox stopped their support for Windows XP/Vista in April 2017
so the last version of 2016 is 1.9.1 from HERE
Never heard of the Cliqz browser-it's quite an interesting concept, though for the time being Mypal has proven a reliable Gecko-based browser for XP.
You've really gone through the paces when it comes to testing browsers--hats off to you, my friend!
The only addons I use on MyPal are:
- the Moonscape addon (for the old Netscape look) (https://addons.palemoon.org/addon/moonscape/)
-QuickJava (look for version 2.0.4.1-signed) (https://addons.mozilla.org/en-US/firefox/addon/quickjava/versions/)
-uBlock Origin (look for firefox-legacy-1.16.4.4) (https://github.com/gorhill/uBlock/releases)
-uBlock Origin Updater (self-explanatory) (https://addons.palemoon.org/addon/ublock0-updater/)
Chris Pederick's trusty User Agent Switcher has never worked in Pale Moon, in any of the many versions I've tried over the years. Thankfully, I don't use it too much these days, but it does come in handy on older Firefox versions (which are now starting to feed 'legacy' pages to FF if your version is older than a certain cutoff point; I use a Firefox 54 user agent to get the latest page versions).
trimis, if you would like to know what I am running for any comparison tests they are in my attachments![]()
Yep, and still questing to try more browsers. Oh, the one I forgot I have was Slimjet. The addons I have for Mypal:
Adblock Latitude 5.01
Ant Video Downloader 2.4.7.50
BetterPrivacy 1.67
Disable Anti-Adblock 3.1.1
Downthemall! 2.0.1.8
Self-Destructing Cookies 0.4.0
Skip Redirect 1.0
Tab Killer 1.1.2007042501
Yes Script 2.2
Most of these I'm just testdriving. Adblock Latitude was cheered on the Mypal site, but I'm not convinced it's doing much....probably will look around for something better. Skip Redirect and Tab Killer are the only essentials. Couple of sites I watch movies and TV shows on was grinding my nerves by opening 5 to 10 tabs/windows for every click, with redirects to hostage sites, porn sites, adware sites, etc., but these two addons ruined their fun!
trimis, I think adobe flash is incorporated into mypal, cannot remember where I read that, probably at the msfn or github forums.
uBlock Origin is more reliable for me than Adblock Plus ever was. I only use Adblock Plus on browsers that are too old to have a uBlock Origin version available for/compatible with them. Thankfully, uBlock Origin has been forked to/works with Mypal (sadly, the legacy version does not work with Firefox 28--I tried to install it unsuccessfully).
