if your av will scan before allowing pc to open them this would be good, also you should have autoplay and autorun disabled:
Turn off Autoplay and autorun:
1. HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
2. If necessary create a dword called NoDriveTypeAutoRun
3. Set the dword thus:NoDriveTypeAutoRun = 000000FF
4. A value of 000000FF (decimal 255) disables AutoRun on all drives.
5. Refer to the above table, and use a Hexadecimal calculator to compute the most suitable value for your machine.
6. There is no need to logoff; the NoDriveTypeAutoRun setting should take effect straightaway
Click Start, click Run, typeGpedit.msc in the Open box, and then click OK. Under Computer Configuration, expand Administrative Templates, and then click System. In the Settings pane, right-click Turn off Autoplay, and then click Properties. Note In Windows 2000, the policy setting is named Disable Autoplay.
this ensures that no removable media can start without prompt from you thru my computer, it only takes seconds for virus' to spread from removable media if the above are not turned off, 360 TSE does this for me,
I can’t seem to get Gpedit to show the system and I can’t find the update for that online
so I put it in my windows 10 machine to reset all of them and the First one I did was previously a xp password recovery disk. I used sd card formatter and now my windows 10 machine stopped working saying it has no boot device found at allif your av will scan before allowing pc to open them this would be good, also you should have autoplay and autorun disabled:
Yep they’re there now.do not know anything about win 10
https://www.winhelponline.com/blog/restore-missing-folders-group-policy-editor-xp/
will explain how to get system subset added to gpedit.msc
I am running 360 TSE. Do you think I should disable Autorun and Autoplay inspite of having 360?this ensures that no removable media can start without prompt from you thru my computer, it only takes seconds for virus' to spread from removable media if the above are not turned off, 360 TSE does this for me,
This goes for me too. Did it in Registry and Gpedit both360 has a setting to disable autorun, but I always have it done in the registry and gpedit.msc, never hurts to be safe,
