Audio Card/drivers
Discussion in 'Windows XP Hardware' started by FiftyCalP0TAT0, Apr 25, 2015.
  1. FiftyCalP0TAT0
    FiftyCalP0TAT0
    So, I installed Windows XP on this old HP laptop I was given. It works fine and everything, but I don't have any drivers, so the only things that work are the screen, track pad, and keyboard.
    How would one go about installing the correct audio drivers if no audio card is detected?
  2. FiftyCalP0TAT0
    what is the make, model and model number of the hp pc??
    you can download the correct drivers from the hp website.
    Elizabeth23, Apr 25, 2015
  3. FiftyCalP0TAT0
    FiftyCalP0TAT0
    HP Compaq nc6220 (EH167UC#ACA)
  4. FiftyCalP0TAT0
    FiftyCalP0TAT0
    Installing the WLAN driver was really easy because it says the exact radio model I needed drivers for. With audio, it's a different story.
  5. FiftyCalP0TAT0
    FiftyCalP0TAT0
    I checked their site and found my model. The only thing they have is the WLAN driver, which I already have. If I change the OS to Vista, it has the audio driver, but none for XP.
  6. FiftyCalP0TAT0
    FiftyCalP0TAT0
    Okay, I got it to work. I installed the XP home edition drivers from the HP site and it worked. Thanks Elizabeth! You were a tremendous help because I had no idea HP let you download drivers from their site.
  7. FiftyCalP0TAT0
    good work, all the major manufacturers let you download the drivers, :)
