I use Superantispyware in ADDITION to Malwarebytes, as the former removes adware tracking cookies, and whilst they are usually considered not harmful, one site which I use regularly, unfortunately, downloads them by the thousands, and I do not want them consuming my bandwidth and BB data allowance.
Also use spybot 'Antibeacon', but on W10 not XP.
every now and again I run adwcleaner, version 6, and the junkware removal tool JRT, and then just my AV, (360TSE), and malwarebytes free.
	when you ask for details there is on the bottom a place to click for a text file, see below: you would click on save results , that will give the full address of the item.
https://filehippo.com/download_adwcleaner/74347/
download from above, it is version 6 that I use, since the later ones do not work on xp.
NOTEPAD: when something says save to notepad, what that means is that the item that you want saved has been placed in clipboard (copy) and you can now paste into notepad. then you can save the report.
if it is a PUP that is not malware that is a potentially unwanted program that according to their list is a bad program, if you decide to keep the program then just remove the check mark.
how to get to notepad:
start / all programs / accessories / notepad
I'm looking at these right now:
Spybot: Search & Destroy 2.4
Superantispyware
Others not specifically anti-spyware (but close enough):
Malwarebytes Free
Adwcleaner
Junkware Removal Tool
That's about all I could find for XP. Which ones do I need, or should I have something not listed?
I Am Setting Up An Old Windows XP Machine That Use To Be On A Domain I''m Thinking About Re-Installing Windows XP Then Reconnect To Domain Any Suggestions On Security?
SpywareBlaster (freeware).
Superantispyware Free version. I don't like any spyware or virus software to run automatically.
I only scan suspicious downloads and occasionally do a C:/ scan.
A good hosts file to block known bad domains.
All I ever find with anti-spyware is tracking cookies.
Host Administrator is freeware that I use to ad popup web pages to the hosts file.
Example: popup.com = 0.0.0.0
If you have XP 32 bit you may want to try out Malwarebytes anti-exploit.
Okay so I now have in place Malwarebytes Free, and Adwcleaner, and quite happy with both. Have not been able to track down which version of Malwarebytes Anti-exploit works on XP (I know one of them doesn't). I could be wrong (correct me if so) but i think SpywareBlaster is mostly to shield IE, which I intend to uninstall, so not sure if I need it or not. I'd like to get Superantispyware, but cannot seem to track down the free version download...every time I try for it I get switched to the paid one. I have studied the hell out of host file, software like HostExpert, etc., and I am just not making any progress. I think this is an advanced topic that is out of my league for now. Kinda like Sandboxie, VirtualBox, and so on.
