Joe511 Nov 2, 2015 #1 Hi, I have a WinXp IBM pc and I plugged it in through ethernet (it doesn't do wireless) but it cant find my ip adress. What can I do?
Elizabeth23 Nov 2, 2015 #3 go to start/run/type in cmd and press ok in command prompt type in ipconfig and press enter your ip address will be listed ========== you should update to serpice pack 3!!!
Joe511 Nov 2, 2015 #4 Elizabeth23 said: go to start/run/type in cmd and press ok in command prompt type in ipconfig and press enter your ip address will be listed ========== you should update to serpice pack 3!!! Click to expand... Thanks will try when I get home
Joe511 Nov 3, 2015 #6 Elizabeth23 said: okay, let me know. Click to expand... Worked, wasn't my ip how can I change it?
Elizabeth23 Nov 3, 2015 #7 http://www.hotcomm.com/FAQ/FAQ_staticIPXP.asp read through the above article and then follow the instructions.
