xp pro
hi my XP PRO S/P3 has 2 hard drives,
the c drive has the operating system on it,
the d drive had my data / files etc
my d drive is corrupt , i can only work in safe mode and i cannot connect to my ISP.
please advise how i can wipe all of the data etc on my d drive, i have all backed up on other computers, saving any data is not required,repeat :) saving any data is not required, thank you donar
you can select the drive in disk management and choose to format,
you can download CCleaner, which has a drive wipe on it
you can download and burn DBan to a cd , but you will have to insure that you choose the correct drive to wipe.
Darik's Boot and Nuke (DBAN): http://dban.org/ Use ImgBurn to create a bootable CD from the DBAN iso file: http://www.imgburn.com/ Both DBAN and ImgBurn are free. How to use ImgBurn: http://forum.imgburn.com/index.php?/topic/61-how-to-write-an-image-file-to-a-disc-using-imgburn/
https://www.piriform.com/ccleaner/builds
ccleaner portable
http://pcsupport.about.com/od/windowsxp/ht/format-hard-drive-xp.htm
formatting with disc management
