Hi, I've got a Toshiba Satellite laptop running XP I'm trying to repair for a friend.
It has an odd fault. It will start and run fine on the battery, and the battery will charge OK from the power lead, but if you try and start it with the power lead connected it gets stuck in a restart loop, restarting at the windows XP screen. If you put it into safemode it start fine on the power lead, but all the diagnostic startup options under msconfig also causes a restart loop. I've tested the power lead and it is OK, also I have tried a power lead from another laptop the same and the laptop still behaves the same.
Anyone got any ideas what the cause is? Thanks.
