Reassign drive D:
Hello:
I’m trying to execute a Microsoft Basic program I compiled in 1995 or so. The program comes up and correctly displays the GUI on the Compaq Presario X1000 described below. However, the input/output files used are hard coded in the program as residing on drive D. The Presario I’m using has an unreliable CD drive defined as drive D.
The Presario does have a USB port that can read and write to a thumb drive. How can I reassign the thumb drive, or another drive, to behave as device D in place of the CD drive?
Any information you can provide is appreciated.
Thanks,
John
OS Name Microsoft Windows XP Professional
Version 5.1.2600 Service Pack 1 Build 2600
OS Manufacturer Microsoft Corporation
System Manufacturer Hewlett-Packard
System Model Compaq Presario X1000 DM774A#ABA
System Type X86-based PC
Processor x86 Family 6 Model 9 Stepping 5 GenuineIntel ~1495 Mhz
BIOS Version/Date Hewlett-Packard 68BAL Ver. F.09, 8/15/2003
SMBIOS Version 2.3
Load the Disk Management window.
What drives are listed there and what are their assigned letters?
If there is only the hard drive and the disc drive and they are assigned the letters C: and D:, change the assigned letter for the disc drive to E:
After you're done, restart the computer.
When you insert the USB thumb drive, it should (but no guarantee it will) assign itself the drive letter D:
it might be better if you go into the bios and disable the cd drive, then reboot, this will give the next drive the letter d but as long as the cd drive is active, then windows will give it the d letter.
Bad news. Since this PC hasn't been used for years, I updated the date/time the last time I started it. After that, I received multiple requests to activate the OS but replied "no" to all of them. Now, I'm being forced to activate, but I'm not able to activate even if I call the 888 number provided by Microsoft. This PC was never connected to my current network.
Is there a way to get this OS activated? I am the original owner and beyond the product key noted on the back, all other documentation is long gone.
Thanks,
John
I'm up and running with a new D drive. My thanks to you both for your help.
How do I formally acknowledge you on this site?
John
I actually used both suggestions. I first disabled the CD drive then restarted with the jump drive attached. The jump drive was still assigned as drive E so I loaded the Disk Management window and renamed it to D. Easy peasy!
John
I do have another question but I'll put it in a new tnread..
