Though having used later Absynths I always prefer this old one for best sound in analog style, best GUI well before they went with that terrible 'flat' & 'small' garbage...
This GUI easy to read & in style as well...
I have included a buncha GLO banks that all been tested in this version, Place them in the 'BIN' folder where you install...
This standalone has a wrapper with a recorder, a few years ago I recorded a buncha samples using just the wrapper these are included as well...
You can install & play the keyboard with a mouse or go to 'SoundCo Software' there is a freeware version of Virtual MIDI Controller which will install a virtual MIDI port for itself (REBOOT) this will show as option in Absynth and others now so one can use QWERTY for entry...
Installs also as VSTi & DXi... This old Absynth needs the 'engine' to be running which it will start itself usually no problems with DAWs using directsound but can be issues with those using ASIO, still works but with a few workarounds I have included an RTF outlining such...
You should copy Cereal to clipboard before install it will ask after completion...
https://send.now/6k35qdy62izh
https://gofile.io/d/vduJXE
https://www.sendspace.com/file/1prjez
https://workupload.com/start/gjCDCEQYsZP
