Need help to save XP updates.
From Windows Update Catalogue, I want to manually download and save XP updates to my external hard drive for future use. I want to chose the updates I want and not install all updates. That is why I want to download manually and save them. How should I go about this so that I can easily install them when the need arises? I don't want to slip stream them. Some help would be most welcome.
Thank you
download into a folder (name it what ever you want) then cop paste onto you external drive or just do same on your external drive save the messing about :)gl
long live xp:)
