Max memory?
A program that I want to run on XP requires 2GB of memory. What is the maximum memory that can be used under XP? Thanks, Jim
The practical limit on how much RAM a Windows XP computer can use is about 3GB. Thus, if you put 4GB or more in, you're just wasting money. Adding any more than you have now (assuming you have less than 3GB) is good; getting to at least 2GB will make your computer much snappier
from here
according to here you would be better off with a better video card
I have 2gb installed on my pc, seems fine to me, but I do not play any intensive games.
