In this case I am worried that this might connect to the internet (for instance to update JetClean), and infect me again. What do you think?check to see if jetclean works and if it does then the spyware part has been quarantined, you are good to go.
I suppose I have to get rid of it. It's such a pity because it seemed to work very well, removing hundreds of little things from the computer that we are not even aware of. And such good reviews by users here too.I just would not use jetclean then if it will not give me the option to choose.
Automatic updates can be disabled. But "Check for updates when program is launched" cannot be deselected. The trouble is to remember to disconnect the internet when using it![]()
This is where I downloaded from and there it says, "We've used JetClean for years here at MajorGeeks and it is easily one of the top 3 best cleaning apps available". Now, how do we reconcile this with my experience. In addition to what I show in the screenshots at posts #1 and #10; I did another scan with Malwarebytes after I uninstalled Jetclean and found 28 more places infected by Jetclean! All 28 were found in Application Data and System Volume Information.There are only a few download sources that are still trustworthy.To know which it is try here:
http://m.majorgeeks.com/files/details/jetclean.html
At BlueSprig web page when I clicked on 'Download' I was redirected to the Majorgeeks download page. There is a link there 'Download@Authors Site' (click the link in post above to see). I clicked to download from the author's site, and on the 'jetclean-setup.exe' pop up window it was written that it was coming from 'http://download.bluesprig.com'.obviously this is not a good program, or maybe it was just your download, might try a different download site.
I think the best choice for me is CCleaner. I'll use the 5 .32 version with updates disabled, the last version before Avast got hold of it.according to Techspot they have noticed the pups in all jetclean downloads and have given a list of alternative cleaners
The last time I downloaded something from CNET was about 10 years ago, when they were clean, and from Download.com never.
This is my 1st experience with such a massive infection and from a supposedly reputed website.
