Thanks!While researching, I found this: https://www.codeproject.com/Articles/5107/Applying-Windows-XP-Visual-Styles-to-Applications
This is an instruction that I found (links below):
ThemePatcher: https://mhoefs.eu/software_uxtheme.php?ref=syssel&lang=en (XP compatibility mentioned, read this guy's german forum posts, no translator)
- Design Graphics:
- Create or adapt graphical elements (buttons, scroll bars, menus) using design software (GIMP, Zbrush etc.)
- Package into .dll:
- Use tools like ThemePatcher or Visual Style Creator to compile your graphics into a .dll file. This file replaces the default system visuals.
- Patch the System:
- Apply the .dll file using a patcher like UXTheme Multi-Patcher. This modifies the OS’s theme engine to recognize and use your custom style.
- Test and Refine:
- Apply the style and test it across applications. Adjust graphics or settings as needed to ensure compatibility and visual consistency.
XP Style Hacker: https://xp-style-hacker.en.lo4d.com/windows
Style XP: https://www.softpedia.com/get/Desktop-Enhancements/Themes/Style-XP.shtml (most relevant)
Github project: https://github.com/Planet-Source-Co...st-maker-for-all-executables-updated__1-27928
Hope these help! If you need any help, please DM me so I can help you faster!
Have fun customizing your XP!
Which one of them worked? I'll be honest, I haven't tested any, just got them from random German forums...Thanks!![]()
