R raywood Mar 13, 2025 #1 I want to pin a shortcut to an Admin CMD window onto my WinXP taskbar. How should I proceed? I'm running WinXP Pro SP3 in a VM.
Elizabeth23 Mar 14, 2025 #2 You can't "pin" a shortcut icon to the XP Taskbar, but you can drag shortcut icons to the Quick Launch Toolbar? Is that enabled? Right click on the Taskbar | Toolbars and check it. Unlock the Taskbar to adjust the size as you want it. above from link below Redirecting
