Elizabeth
Thanks for the info. Firefox is installed on Mom's PC but I'm one of those "shortcut keyboard" geeks so I've stayed with IE even though I know the earlier versions are less secure than Firefox.
Firefox ported over a lot of the default MS/IE browser keyBd shortcuts but there's one that they didn't duplicate, which I use many times daily in IE.
I have Firefox installed on my own Win 7 PC but as a backup browser and also as a tool to eliminate IE as a possible issue with particular sites.
Jojo
Thanks for the info. I'm not familiar with XP since I haven't used it on my own PC's since 2010 but I google'd up a little info related to your suggestions about disabling Updates and networking services.
Are the following the correct steps regarding disabling Updates?
1.Click Start, Settings, and Control Panel.
2.Open System
3.Click the Automatic Updates tab.
4.Check or Uncheck the option for Keep my computer up to date.
5.If you are enabling this feature by checking this box, select one of the three settings
on how you want to be notified for updates. We would recommend you select the second
option, Download the updates automatically and notify me when they are ready to be
installed.
6.Click Apply and Ok.
Networking Services, I found this info:
How to Access Your Microsoft Services:
1. Click Start.
2. Click Settings.
3. Select Control Panel.
4. Double click Administrative Tools.
5. Double click Services.
6. Scroll down, and highlight the service you want to adjust.
7. Right-click on it, and choose Properties.
8. Click the stop button.
9. Select Disable or Manual in the Startup Type scroll bar.
Are you recommending to disable all of the Services that appear on the list?
Misc info on my Mom's XP PC:
I check her PC every morning to see if all's looking ok. I usually take a peak at "Process Explorer" and run a quick "Netstat -b" script to look at what's connected in TCP, just to look for something that appears abnormal.
I also check the CPU usage (Task Manager) at a "Desktop Idle" state, to see if anything's using an abnormally high amount of usage.
So far, all's ok but I did notice,. earlier this week, a yellow "update" shield appeared in her System Tray. The update was waiting to be installed but didn't display any specific info when I clicked on the shield.
I wasn't concerned since I have multiple backups of my Mom's PC (full-HDD Images stored elsewhere as well as a cloned HDD).
However, the shield reminded me of the old days where malware would appear in the Sys Tray as one of those "official-looking" MS update shields.
I was going to shut down the PC and install the cloned HDD to eliminate that Sys Tray pending update (or malware) but the PC automatically installed the update during the PC shutdown sequence.
After it installed, I booted up and all looked ok. I checked the Update list in Control Panel and it appears that this was a legit Firefox update but I'm not as familiar with XP so I didn't dig deeper for additional update info.
Mom's PC appears to be working ok a few days after that update so I'm almost certain that all's ok.
It not, I'll install the cloned HDD or restore from several Image choices. I ran an Image after the last MS updates on Apr 8, just in case it's needed later.
I've done some preliminary checking into "Open Office" and that's a good idea to pursue. If it allows *.PST imports, I might set that up on Mom's PC soon.
I have Linux Mint in my own PC's bootable media tool kit and have booted up with it on my Win 7 PC but haven't spent much time getting familiar with it yet.
That's a possibility for Mom's PC.
The main downside to the various alternatives with Mom's PC is that I'd have to re-train her with those alternatives. She's not PC-savvy and she also is an infrequent PC user so I'll have to weigh the considerations, training issues vs security concerns.
Over the last few years, I've gotten familiar with cloning and Imaging and since BIOS/firmware malicious intrusions are rare, recovery from nearly all malicious intrusions are usually fast if one is backing up the HDD regularly.
The one issue that's more if a concern for me with Mom, is identity theft. However, she rarely does any transactions on the XP PC (no banking transactions, and rare CC purchases).
I monitor her CC's and her Bank acct at home on my Win 7 PC to catch any fraud items that way.
Bottom line, is that I'm taking a "show me" approach regarding the XP expiration issue as it relates to potential threat possibilities.
I agree about the over-emphasized "doom" predictions. There is definitely an increased risk factor with XP after Apr 8th. That's something anyone should acknowledge.
However, this is my take on this, but it seems that the naysayers are plentiful around the 'net when I've tried to discuss this topic at other forums. That can act as an impediment when attempting to obtain specific answers to questions as the discussions will invariably turn into "What are you doing still running XP", or "Your PC is probably already compromised."
That said, I'll have to see how it goes. If Mom's PC gets hit with the usual browser hijacks/popup's/ransomeware sceen malware items, I'd have to look into the alternatives.
I'll be looking at the frequency of potential future malicious intrusions and then make a decision on how to proceed.
I'm not concerned about, say, 1 or 2 incidences in a year's time, as long as those intrusions are confined to the HDD as nearly all infectious items will be in that category.
The PC is a "fossil"
, circa 2006 HP Slimline PC so in the rare chance that the BIOS or MoBo gets compromised, it would be time to get Mom a new PC.
