help with sata temp set-up
hi i am in kind of a unique situation...i have another pc that i am working on (my main)..it has has serious issues and i cant boot it or do anything so i am trying to hook it up to this pc so i can move some files before i do a complete wipe of the other drive....i have hooked it up to my pc but it doesnt show in "my computer" for me to access any files...basic info below
amd 3200 processor
win xp os
asus k85-la mobo
the drive shows in device manager but doesnt show anywhere-else...any help greatly appreciated for helping me save some stuff before i wipe it :-(.
you can burn a copy of hirens and get at your drive to download all your files, or see if running checkdisk can allow you to boot.
Courtesy of Jose Ibarra
http://www.imgburn.com/
cmd
chkdsk c: /r
First let me say thanks for the thorough and user friendly post..i knew most of what you put in there but boy it woulda saved me hours if you didnt :)..good news..that hirensboot is the best thing since sliced bread...easy to download unzip burn and use..an absolute god-send...everything you could want packaged up nice and tidy...was able to use all the utilities i wanted with ease....now the bad news (for me)..i was convinced i had a software or secondary hardware problem(gpu card)..but in running this program and another i was able to access on my main pc it seems that the hd has simply begun to/completely failed..i am shocked as it is less than 2 years old...i am running other that are now going on 11 from WD which this one also is..ty so much for this program link..now i need to find one that is 8.0 compatible so i can put it on my main if/when new problems arise :).
sometimes you do not know when a hdd will fail, I know people who have gotten a bad one from the factory.
I often run checkdisk just to see if an kb's are in bad sectors, cause that is a sure sign that the hdd is failing. :)
