Hi People,
I seem to have accidentally corrupted my environment / system variables. (XP + SP3)
I was adding "SEE_MASK_NOZONECHECKS=1" via the "System Properties" +"Advanced" + "Environment Variables" + "System Variables" dialog,
but I think there was a "hidden character" preceding the "SEE_MASK_NOZONECHECKS" in the clipboard string.
Now any changes I make will be lost (to the dos environment) after a reboot, although they still show up in the dialog, and the "SEE_MASK_NOZONECHECKS"
can't be seen in the dialog, but is always in the dos environment with a preceding white space character.
I tried using the "Rapid Environment Editor" tool, as well as searching and striping the registry of all occurrences "NOZONECHECKS" but nothingseems to work.
On reboot the dos prompt "SET" command always shows"zSEE_MASK_NOZONECHECKS=1" with a preceding white space character where the 'z' is shown.
My gut feeling is that I need to edit "a file" with a hex editor and remove the offending non-printable character, but I don't know where "the file" is to be found.
Can anyone offer me any suggestions?
