Moderator
Well I have an old Compaq laptop from 2004. Max memory is 512MB so forget about Vista, 7, etc.
Since the major browsers have abandoned XP I've been test driving some of the Mozilla forks for modern website compatibility. The 3 mozilla-based I have found to be most compatible are Newmoon, MyPal and Basilisk. Of these 3 my favorite is MyPal. Although it only scores 423 out of 555 on http://html5test.com/ I have found it to work perfectly with practically any modern website I've accessed it with. Built-in H.264 support, WebM/OGG etc. means it will play practically any online video WITHOUT flash. I have tested with Youtube, Facebook, Instagram, Vimeo, CNN, ESPN, BBC Iplayer, Putlocker, etc.
(I hope none of you are still on dial-up)
Yes I am using Moonscape theme for that good old-fashioned Netscape Navigator feel. I have only a few extensions loaded.
I have heard rumors that MyPal has adblock built-in but I couldn't find anything in options to indicate this so I added UBlock which I have been using for years on Chrome and Firefox. The trick is you have to enable practically every filter in filter lists and update.
Another thing I like about MyPal is the portable option when installing - take your browser with you along with all your bookmarks, extensions, etc on a flash drive.
Hopefully MyPal will continue to be updated periodically for compatibility.
I think dependency on Adobe Flash for anything web is at an end. The only plugin I keep is Silverlight since that's the only way to watch Netflix on XP.
