Best method to downgrade MyPal Browser
I started having issues with Mypal 14.7b a few weeks after the upgrade. At first I was very happy with it, but now it not only loads very slow, but when ever it’s running all other programs also load very slow and exhibit delayed responses to any interaction.
I’m not sure exactly how to diagnose the issue, so I figured I would first go back to V.13.7b after completely purging everything “Mypal” from the system.
Is this purge as simple as deleting directories and registry entries, or could Mypal also be affected by other browsers on the system? (Serpent, Firefox, Chrome)?
Also, if there’s any way to keep profile settings that cannot be part of the problem, that would be very helpful. Bookmarks are easy enough, but I’ve never figured out an easy way to save individual settings for allowed cookie storage and such.
Thanks for any input,
Wolf
go to troubleshooting and you can open the folder for your profile.
what I do is copy the entire folder to desktop, after you have closed mypal, and then when I install mypal, I just copy the entire folder to the new profile folder and check box to replace all with new files.
