With a combination of a few programs I use for doing light graphic editing (PSP5, PSP7, Promotion, Anim Shop 3), I created some modified cursors to use in Windows XP.
Bear in mind, these are cursors using the largest available size to the operating system, which is 32x32 pixels, same as the Windows Standard Extra Large scheme for pointers
Two types of "working" pointers, one with the spinny circle vertically up, and another vertically down. Mouse cursor itself is in front.
One cursor is the "busy" pointer, where it's just the spinny circle in 32x32 format (instead of 48x48 that later windows versions use).
All 3 wrapped in a zip file. Unfortunately, I could not directly upload *.ani (animated cursor) files.
