Adding Mac scsi drive
I have a stand alone work computer (no internet) that is a 1992 Mac with a SCSI drive in it. I have a newer donor E machine 733i that I installed XP with SP2 on it. I have installed a Adaptec 29160 SCSI adapter.
When XP boots I can see the SCSI drive being detected and I see it when the SCSI utility comes up right after the bios no errors on booting.
But when I go to My Computer the drive is not there. If I go to device manager I can see it.
The drive I believe has Apple 7.5.1 and Apple Share 4.0.2 which I know will be problem for XP to read. The program and files I am after I think are DOS 3.3 and Old Foxpro.
I installed Foxpro on the XP machine also.
Basically I am after the database on there to get it moved to a newer machine.
So I think my problem is Mac / XP issue, but could there be anything else?
Is there a way to see the drive from XP?
Thanks duder
I found ufs-explorer and it claims to install on XP to access several types of file systems. Anyone familiar with it?
Duder
