Hello guys,
So im trying to install a program called Carsoft 6.5 which is a d iagnostic tool used for older BMWs and to use this program i need Windows XP. I have used VirtualBox to do this and installed Windows XP there and managed to get the files over to that virtual computer. But when i open the setup for the program and try to install it, I get a error/fault message as follows:
16 bit MS-DOS Subsystem
C:\user\appdata\Local\temp\CCMV32AA.exe
The NTVDM CPU has encountered an illegal construction.
CS:056b IP:168b OP?e 4a 42 95 08 Choose "Close" to terminate the application
[CLOSE] [IGNORE]
What should i do to fix this? Is it because Virtualbox? Because the program was designed for XP and i dont get why i get this error. I also get it while trying to install it on Windows 10 using compability mode.
[CLOSE] [IGNORE]
