Windows XP Forums
Reply
Thread Tools Display Modes
wireless printer shared problem
Qnguyen
Guest
Posts: n/a
      16th October 2007
Hi,
I have Vista laptop and 2 PC connect to wireless router. I try to set up a
home network( same work group) then try to share local printer on Vista
laptop. However, I am not able to browse the printer in PC for printing or
even folder shared on Vista laptop. Do you have any clue? Thank you very much.
Byte
Guest
Posts: n/a
      17th October 2007
Host should be the desktop PC and Guest the laptop. You may want to print
this.
Install the printer on the Host PC. Then using Control Panel>Network
Setup Wizard, enable File & Printer Sharing and make sure you check the
box to allow others to print to your printers. Next under Start>Settings>
Printers, select the printer, check the box to share the printer and assign
a name. Keep the name short, no blanks, something like Printer2.
You should now be able to add the printer to your Guest PCs using Start>
Control Panel>Printers & Faxes>Add Printer. Check the radio button
"A network printer ..." and then either browse for the printer or enter its
name (using \\PCName\PrinterName) and continue until finished. Ensure
that the firewall on your PC is set to allow access to remote printers.
Note: Make sure to include the slashes (\\) in printer name.
If using Vista's native firewall ensure that File and Printer Sharing is
enabled and that the box with he same name is checked in the Firewall
exceptions list. The PCName can be found at:
Rightclick My Computer icon on desktop>Properties>Computer Name tab.
It may look something like: "Home-66djksjcpv". Don't type the quotes.
Click "Next" and it should install the printer on the Guest PC when
it finds it.
Note: You can follow the same procedure to get access to
"Files" from one PC to the other.
XP - WNP
Today is the first day of the
rest of your life.
"Qnguyen" wrote:
> Hi,
Qnguyen
Guest
Posts: n/a
      17th October 2007
thank you very much Byte.
I still have problem with set up newgroup from windows vista home. There no
option like windows XP to create home work group.
I just change the name of workgroup from computer name tab. However, I could
not browse the workgroup in Vista (actually I do not know where to go to find
it) Vista is very new for me to use.
Thanks
> this.
> it finds it.
> XP - WNP
> rest of your life.
> "Qnguyen" wrote:
> > Hi,
Byte
Guest
Posts: n/a
      18th October 2007
Sorry, I do not have Vista and do not plan it for at least another year.
XP - WNP
rest of your life.
> Thanks
> > this.
> > it finds it.
> > XP - WNP
> > rest of your life.
> > "Qnguyen" wrote:
> > > Hi,
Cari \(MS-MVP\)
Guest
Posts: n/a
      18th October 2007
Doubleclick on My Computer, then about half way down the screen, you'll see:
Computer name, domain and workgroup settings....
Click on Change Settings to set the workgroup name, and then reboot.
Cari (MS-MVP)
Windows Technologies - Printing & Imaging
http://www.coribright.com/windows
"Qnguyen" <(E-Mail Removed)> wrote in message
news:B665F08D-D000-4AF6-93CA-(E-Mail Removed)...
> no
> could
> find
> Thanks
>> print
>> this.
>> assign
>> its
>> it finds it.
>> XP - WNP
>> rest of your life.
>> "Qnguyen" wrote:
>> > Hi,
>> > up a
>> > or
>> > very much.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Shared printer problem 4red2 Windows XP Printing / Fax 2 12th October 2007 12:46 AM
Shared printer problem. David Goldberg Windows XP Printing / Fax 1 8th May 2006 06:26 PM
setting up a shared printer on a wireless network misterfixit1967@gmail.com Windows XP Printing / Fax 2 18th January 2006 02:33 AM
Cannot access a shared printer on my home wireless network Sheina Windows XP Printing / Fax 3 4th January 2006 03:11 AM
Need help printing in XP on Mac shared printer from wireless network Need2Print Windows XP Printing / Fax 1 17th February 2004 02:36 AM
Windows XP Forums is an independent website and is not affiliated with Microsoft Corporation.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
