Mike Vandeman wrote:
> I have a little wireless/wired Ethernet network in my home/office
> with three PC's, an Xbox 360 and a wireless network printer. I like
> to use the Internet speed test at www.whatismyip.com to benchmark
> my Internet speed. The server in San Francisco records the best
> results, upto 25 mbps download and about 500 kbps upload. The San
> Francisco download Internet speed results appear to be right at the
> top range of the theoretical signaling rate of my Internet cable
> modem speed.
> I noticed that the download speeds on wireless are only a fraction
> of the wired Internet speeds. In both cases the highest speeds are
> only a fraction of the theoretical speeds, 54 mbps for 11g wireless
> and 100 mbps for wired Ethernet. Also the LAN wireless speed is
> slower than LAN wired Ethernet speeds.
> Why is this so? Is there a larger hardware/software overhead for
> wireless networking?
> What are the implications for Gigabit Ethernet or for 11n wireless?
> Thanks for the enlightenment.
What type of Internet connection do you have?
(What speed do you pay your Internet Service Provider for?)
What does
http://www.speakeasy.net/speedtest/ give you for speed when
connected by wire?
(Yes - I saw you did the test at whatismyip.com... I would still like you
to try a couple of cities at the above site - particularly any *close* to
you.)
What does
wireless?
you.)
Were the above two tests done on the same computer/device?
Do you have the most up-to-date wired and/or wireless device drivers from
the actual hardware manufacturer of each device (Microsoft is unlikely to
have been the one to manufacture either of those devices - don't get your
hardware device drivers for these devices from them)? Visit their web
page(s) and find out. (Belarc Advisor or just Device Manager can help you
figure out what manufacturer and what device you have.)
I get ~11,500kbps download and ~1,000kbps upload at home on a cable modem.
My grandmother pays much less and gets about 1300kbps download and 320kbps
upload speed on her DSL. All of those numbers are reguardless of
wired/wireless (given a good wireless connection/strong signal) since
neither is anywhere near the 54Mbps theoretical maximum wireless or 100Mbps
maximum wired (the actual maximum is always less.)
At work I get ~95,000kbps download and ~18,000kbps on wired, but top out
wirelessly for the download speed due to the limitation (right now) of using
wireless g technology.
All of the Internet tests are affected by many things. What version of
Flash you are running, for example. The processor speed of your computer
could even be a factor. The drivers for the network technology you are
using. The time of day and how many other users using the same speed test
or even the same ISP you are. The path that your ISP takes to get to the
test site you choose to use.
However - if you say you have ~25Mbps (~25,000kbps) download speed and
500kbps upload speed (although what a strange combination, IMO, of speeds to
pay for) then I'm not sure you really have much to worry about in terms of
using the Internet.
Perhaps just being picky, but it's 802.11 or at least ".11"... ;-) Wireless
a, b, g or n right now.
802.11 (2Mbps theoretical max)
802.11b (11Mbps theoretical max)
802.11a (54Mbps theoretical max)
802.11g (54Mbps theoretical max)
802.11n (>100Mbps theoretical max)
If you are getting a significant drop in speed between a wireless connection
to your LAN vs a wired connection to the same LAN --> then you need to look
at *your* equipment and drivers. Router updated? Router configured to give
you the best speed? Wireless network devioce in your computer(s) updated
with the latest driver from the manufacturer? System up to date with the OS
and application drivers?
What if you test the transfer speed from one computer to another with one
being on wired and the other being on wireless within your own LAN? What is
the transfer speed between the two like? You should grab a good ~60% of the
wireless maximum speed or more.
Shenan Stanley
MS-MVP
How To Ask Questions The Smart Way
http://www.catb.org/~esr/faqs/smart-questions.html
