wikipedia on browsers
Discussion in 'Announcements, Suggestions and Feedback' started by Elizabeth23, Apr 4, 2016.
  1. Elizabeth23
  2. Elizabeth23
    Note 1:
    well so much for pale moon, :)
  3. Elizabeth23
  4. Elizabeth23
  5. Elizabeth23
  6. Elizabeth23
    Well, did not take long, so far the only one I kept was Pale Moon, do not know how long that will last, but below are my notes on these:
    PaleMoon:
    took a couple of minutes for the setup screen to open on my desktop
    pages appear to load a bit faster? Might be because I do not have a long list of addons, :)
    youtube videos played without stutter and or stopping BUT only after I had activated adobe flash, and chosen to allow and remember, could now play a long list on youtube without refreshing page constantly.
    Adobe flash, added with install automatically.
    so far so good, I mean it is based on firefox, :)
    from desktop to homepage about 15 seconds
    360 Total Security flagges as potential virus, I just clicked on Allow.
    Forum rules
    Please use this board only if you are running Pale Moon on official versions of Windows XP, XP Pro x64, Server 2003 or other NT5 based Windows operating systems.
    If you have "extended" Windows XP past its end-of-life date, then your posts do not belong on this board and should be posted in the Windowx XP Embedded/POSReady2009 board.
    could not find cache folder so I can clear it offline, so I have to clear history each time before I close it.
    Maxthon:
    check advanced:
    otherwise it will automatically make it your default and will create a quick launch icon
    would not let me have yahoo as my home page
    therefore uninstalled right away, no other testing
    Vivaldi:
    check advanced for more detailed install instructions
    first opening after install, told me my connection was insecure, so I clicked on back to safety and got a blank page, closed out and reopened, everything was fine???
    after trying a few tabs and every now and then getting an insecure connection, I just uninstalled this
    SeaMonkey:
    slow on you tube
    cannot change homepage, uninstalled
    no further testing
  7. Elizabeth23
    Jody Thornton
    Richmond Hill, Ontario
    So if you go to the Pale Moon menu, choose "History" and then "Clear History", the list of items you want to remove will be checked (ie. cache, search history, browse history, cookies, etc...) will be removed when you press OK.
    Jody Thornton, Apr 4, 2016
  8. Elizabeth23
    Jody Thornton
    If you go to Edit -> Preferences, the screen to change the home page is in there. Done it a million times.
    SeaMonkey is a great browser. I'm surprised that YouTube would not play without Flash. I had Pale Moon using just the HTML5 player (it takes a second to detect that Flash is not present, but then works.). But I'm on Windows 8, so I wonder if that makes a difference.
    I know that embedded videos on Twitter will NOT work on Windows XP, no matter what because a codec is missing in the OS.
  9. Elizabeth23
    well, I might reinstall seamonkey to test this out , since I want to be able to customize any browser. :)
    as for history in pale moon, yes I can clear manually through the history, while pale moon is open, however this is not how I want to do it, with firefox, I have the cache2 folder in my start menu and I can click on it and select all to delete, this makes ccleaner when I run it go much faster as evidently window is much faster at deleting than ccleaner.
    so I want to have a folder from pale moon in my start menu also so I can delete when I choose. :) I deleted several folders one at a time to see if the history was gone when I opened pale moon, but did not find which folder it was. :(
  10. Elizabeth23
    Jody Thornton
    Well, under Documents and Settings\Elizabeth\Moonchild Productions is there a Pale Moon\Profiles\[something]\cache folder?
    (I only use memory/RAM cache, and disable disk caching, so I don't have it)
    Jody Thornton, Apr 5, 2016
  11. Elizabeth23
    yes there is and I tried to delete this and several others in this folder to see if the history was gone when I opened pale moon, but the history was always there, :)
    Elizabeth23, Apr 5, 2016
  12. Elizabeth23
    ScaleCraft
    On CCleaner, you can select cookies to keep for log in and such...I never have any real issues with speed on CCleaner.
    I have FF29 on this tower, 12.0 on the other here, 41.0 upstairs. I much prefer older FF versions..less "garbage" on screen.
    I also kill by renaming all updaters, as I do NOT want my programs updated to something that won't work with XP.
    Makes life easier.
    Dave
    ScaleCraft, Apr 8, 2016
  13. Elizabeth23
    Jody Thornton
    The current build of Firefox does work on XP. I use it at work everyday. But yes, Australis, and now the reworked Otions and Add-Ons page are more mobile-like.
    Jody Thornton, Apr 8, 2016
  14. Elizabeth23
    Touko White
    Margate
    I personally like Australis, I don't see a problem with it myself, although a lot of people seem to. (also, post date is nice.)
    Touko White, Jun 5, 2016
  15. Elizabeth23
    trimis
    For anyone interested, these are the browsers I have confirmed will run on XP Pro:
    Black Cat 0.1.1
    Blackhawk Web Browser 1.0.195
    Clicqz 1.15.0 or 1.14.0 (not sure yet)
    Cometbird 11.0.2012.04.01
    Dolphin 3D Web Browser1.60 to 7.0.6000.16640
    Dooble Browser 1.60
    Epic Privacy Browser 62.0.3202.94
    Fast Browser Pro 8.1
    Internet Surfboard 0.0.4
    K-MeleonCCF ME 0.096.5
    Lenstaros Browser 4.0
    Otter Browser RC4
    Qupzilla 1.8.4
    Runecats Explorer 1.7.2
    Secure browser 5.2 (Dell Kace)
    Slimjet 7.0.1.0
    Snapso Web Browser 1.0.1
    Torch Browser 25.1
    Ultimate Browser 3.1.1.0
    Usejump 0.10.5 Beta
    Vivaldi 1.0.303.52
    WebGoo 6.0
    Zeromus Browser 4.3
    When I say "confirmed", I have done so on paper. I have yet to download/trial any, as I have gone through so many browsers over the last few months, I'm a bit burned out. Will start test driving again next month. FYI: I have download links if any above prove elusive.
    trimis, Jan 23, 2018
