USB Mouse stopped working
Discussion in 'Windows XP Drivers' started by djpete1959, Nov 23, 2019.
  1. djpete1959
    djpete1959
    After trying many things I am out of ideas.
    I have 2 identical hp compaq 6710b laptops but one has the mouse not working.
    I copied the usb files from the working one as per this I found but still no joy...Pls help..
    “Cannot install this hardware. Error occured during installation of the device. Driver installation file for this device is missing a necessary entry. May be because the INF was written for Win 95 or Later. Contact your hardware vendor.”
    This error message refers to a problem with your computer’s configuration and should be investigated with your computer’s manufacturer if none of the other tips help. In your Windows INF directory (usually C:\Windows\INF) there should be three files installed with Windows called usb.inf, wdmaudio.inf and wdma_usb.inf. If any of these is missing you may encounter the error message. To restore one of the missing files, you can try reinstalling Windows, repairing Windows from the original installation CD or copying it from another computer running the same version of Windows as yours. We are unable to provide copies of working INF files; please contact your computer manufacturer for further help with this problem.
  2. djpete1959
    djpete1959
    oh running win xp with service pack 3
  3. djpete1959
    djpete1959
    ps the mouse WAS working before. I also tried system restore but no joy
  4. djpete1959
    does the mouse work in the other laptop?
    do any other usb devices work, i.e. flashdrive?
    Elizabeth23, Nov 23, 2019
  5. djpete1959
    djpete1959
    Thanks for your time.
    Yes. USB drives read fine. Yes the mouse works fine on other laptop. I also tried another mouse with no joy.
    USB Serial Bus Controller shows red x in device manager.
    removing and reinstalling the driver and rebooting all failed to help.
  6. djpete1959
    priscus
    Is it the wrong device driver?
    If someone has installed wrong driver, do you have the option, in device manager to roll back to an earlier version of driver?
    priscus, Nov 23, 2019
  7. djpete1959
    djpete1959
    Thanks. I am the only one who used the laptop. I can't think of anything that would have caused it to happen.
    Unfort no option to roll back. I did already uninstall and still have issue.
  8. djpete1959
    does the keyboard work?
    how did you uninstall and install? unplug mouse , and use laptop keyboard to uninstall mouse, then turn off pc, plug in mouse, turn on and let windows find the device
    Elizabeth23, Nov 24, 2019
  9. djpete1959
    djpete1959
    followed those instructions but i then get cannot install this hardware
    djpete1959, Nov 24, 2019
  10. djpete1959
  11. djpete1959
    djpete1959
    none of those worked unfortunately
    djpete1959, Nov 25, 2019
  12. djpete1959
    priscus
    Sounds as if you are going to have to do a repair console fix, or a fresh OS install.
    Before so doing, make sure your driver/file is not corrupted because hardware faulty. Download 'Memtest86' and check RAM is fault-free.
    https://www.memtest86.com/
    priscus, Nov 25, 2019
  13. djpete1959
    djpete1959
    that software did not work for me.
    I get message when trying to reinstall drivers.
    error occurred during installation
    driver installation file is missing
    this may be because the inf was written for win 95 or later
  14. djpete1959
    djpete1959
    is there any way i can copy files form the identical working laptop?
  15. djpete1959
    Elizabeth23, Nov 25, 2019
  16. djpete1959
    djpete1959
    reformatting will update as i go
  17. djpete1959
    djpete1959
    now getting the file usbccgp.sys is corrupted. press any key to continue...
    Arrrr! lol
    #17
  18. djpete1959
    djpete1959
    2nd time round i am now reinstalling win xp yeah!!!
    #18
  19. djpete1959
    djpete1959
    cant find any hard disc drives. Man Im having a bad run
    #19
  20. djpete1959
    djpete1959
    turned off native mode for sata.. trying again
    #20
