Unresponsive keyboard and mouse please help!
Discussion in 'Windows XP Help and Support' started by Jrod, Jun 3, 2013.
  1. Jrod
    Jrod
    Ok so it all started when I download uninstaller pro to remove a unwanted application. All worked fine until I allowed uninstaller pro to assist with my registry. It was supposed to update or something don't really remember what it said.(which I'm very upset with myself for not paying closer attention like I should) anyways when it prompted me to restart my PC I did and when It came back to the login in screen my keyboard was unresponsive. However my mouse was accessible so I try'ed for a system restore (another big mistake) after the restore finish and returned to the welcome screen both my mouse and keyboard were unresponsive. Oddly however my keyboard works just before windows login screen pops up, I have try'ed everything I can think of to fix this issue such as; unplugging both and plugging back in, restart after restart, changing both mouse and keyboard with new ones, and even tapping f8 to pull up restore still no luck I have no restore Cd so i can't even try that option Please if anyone can offer any advice to this issue It is very much appreciated thank you.
    My PC: 2005 Compaq Presario:OS Windows Xp Media center edition
    Keyboard: Ps2 and USB model (ps2 is my everyday keyboard. USB is new model I purchased)
    Mouse: USB and ps2 (other way around with mouse USB is my everyday mouse and ps2 mouse was purchased as replacement)
    Jrod, Jun 3, 2013
  2. Jrod
    I will give you instructions to burn a cd with Hiren's boot cd, (from a working pc)
    and then you can run recovery console, chkdsk c: /r
    Courtesy of Jose Ibarra
    http://www.imgburn.com/
    cmd
    chkdsk c: /r
    there are other instructions if you have no cd drive, that uses a usb
    Elizabeth23, Jun 3, 2013
  3. Jrod
    Jrod
    thank you so much for the respond i've been pulling my hairout trying to figure this out i notice that you mentioned "other instructions" for "no cd drive" I'm curious as of what might those be?
    Jrod, Jun 3, 2013
  4. Jrod
    Jrod
    I have a question will this restore cause me to lose everything?
    Jrod, Jun 3, 2013
  5. Jrod
    you are not restoring, Hiren's is a boot cd that lets you access your drive it is not an operating system it is a tool.
    here are hiren's for a usb flash drive it is only useful if your pc has the capability of being able to have usb as an option in the boot sequence.
    Courtesy of Jose Ibarra:
    http://www.hirensbootcd.org/download/ (look near the bottom of the page, do not click on any ads).
    http://www.hirensbootcd.org/burning/
    Instructions
    http://rufus.akeo.ie/
    http://www.hiren.info/pages/bootcd-on-usb-disk
    Hiren’s for flash drive
  6. Jrod
    Jrod
    Ok thank you very much...so let me be clear. About burning the image file am I burning
    the Hirens.BootCD.ISO or the BurnToCD.cmd file or...?
    Jrod, Jun 4, 2013
  7. Jrod
    hiren's boot cd. iso as below
    Filename: Hirens.BootCD.15.2.zip
    Filesize: 592.5 MB (621283886 bytes)
    ISO MD5: 7EFC81ADBBD551D56F6021C439C6837C this one
    ZIP MD5: D342BBD6BF7554ABA24A376E41675DBF
    Elizabeth23, Jun 4, 2013
  8. Jrod
    when you enter hiren's desktop you want to check device manager on your c drive and see if any warnings are there and what they are, you might have deleted something that we can restore.
  9. Jrod
    one other thing hiren's also has a registry restore tool.
