Uninstall Programs Control Panel
Discussion in 'Windows XP Help and Support' started by doug4r, Mar 2, 2014.
  1. doug4r
    doug4r
    The line where you specify Change/Remove has disappeared. How do I get it back?
    doug4r, Mar 2, 2014
  2. doug4r
    has it done this for all programs or just one program??
    Elizabeth23, Mar 2, 2014
  3. doug4r
    http://www.winxptutor.com/arpbuttons.htm
    regedit solution, but back up your registry first with Erunt,
    http://www.bleepingcomputer.com/download/erunt/
    http://www.kellys-korner-xp.com/xp_tweaks.htm
    line 337 , right hand side
    NOTE first insure your system is clean, since you did not make this change you might have malware
    1. what is your current antivirus??
    2. what other scanners do you have installed??
    3. do the following:
