Themes refusing to change! Help plz
Discussion in 'Windows XP Help and Support' started by Kitsune713, Sep 4, 2014.
  1. Kitsune713
    Kitsune713
    so every time I start up my laptop I'm thrown into a guessing game of which theme will load, sometimes it's in the XP theme, or it's in classic grey. Either way i am unable to change which theme I get to use, I haven't received error messages when switching between XP, and classic, it just remains in whichever theme it was upon start up, basically it shows that I'm using my choice of theme in "Display Properties", but no matter what theme I choose it is always appearing as either XP or Classic.
  2. Kitsune713
    are there any errors listed in event viewer??
    go to start/run and type in eventvwr.msc the sections you are most interested in are applications and system, check for the time at one of your reboots.
    also, what is your current antivirus??
    do you have any other scanners installed??
    Elizabeth23, Sep 4, 2014
  3. Kitsune713
    ALSO: which theme do you want xp or classic??
    and do you have xp pro or xp home??
  4. Kitsune713
    Kitsune713
    I don't see anything relating to themes, but I'm not entirely sure what I'm looking for, I'm currently using AVG, I want to use XP theme, and lastly I'm using XP pro
  5. Kitsune713
    In event viewer you only want to look at a listing if it is an error, if it is just info do not worry
    an error will be red with an x in it
    a warning will be a yellow triangle with an exclamation point in it.
    if you double click on the entry a dialog box will open with further info
    First, I am not sure if AVG is still supporting xp
    see HERE
    also avg is not considered one of the top antivirus even when xp was still supported, that said
    I want you to download the following and run them, you can uninstall them later if you choose:
    when the scans are clean, NOTE: you may have to run each twice) and the issue is still occurring, then next I want you to create a new administrative account and then log into it and does the issue occur in the new account??
  6. Kitsune713
    ALSO: I will be online for approx another hour, so I will check back.
  7. Kitsune713
    Kitsune713
    Sorry for not replying in so long, college has been a pain. Anyways I ran those anti malware like 12 times and am still getting malware hits, same ones over and over infact, also I tried the admin account thing no luck :/
    Kitsune713, Sep 30, 2014
  8. Kitsune713
    can you post the log from malwarebytes??
    so you created a new account and the same issue occurred in the new account, correct??
    Elizabeth23, Sep 30, 2014
  9. Kitsune713
    Kitsune713
    I created a new Admin account and tried changing themes and the theme did not change just like before.
    Malwarebytes Anti-Malware 1.75.0.1300
    Database version: v2014.04.17.04
    Windows XP Service Pack 3 x86 NTFS
    Internet Explorer 8.0.6001.18702
    Owner :: KEIRO [administrator]
    30/09/2014 10:48:54 AM
    mbam-log-2014-09-30 (10-48-54).txt
    Scan type: Full scan (C:\|)
    Scan options enabled: Memory | Startup | Registry | File System | Heuristics/Extra | Heuristics/Shuriken | PUP | PUM
    Scan options disabled: P2P
    Objects scanned: 312737
    Time elapsed: 1 hour(s), 3 minute(s), 39 second(s)
    Memory Processes Detected: 0
    (No malicious items detected)
    Memory Modules Detected: 0
    Registry Keys Detected: 3
    HKCR\CLSID\{051E9166-B275-4683-907B-372FAE22BC7C} (PUP.Optional.WebSteroids.A) -> Quarantined and deleted successfully.
    HKCR\CLSID\{E5A7A645-8318-4895-B85C-EDC606B80DB6} (PUP.Optional.DynConIE.A) -> Quarantined and deleted successfully.
    HKCU\Software\DynConIE (PUP.Optional.DynConIE.A) -> Quarantined and deleted successfully.
    Registry Values Detected: 0
    Registry Data Items Detected: 0
    Folders Detected: 0
    Files Detected: 1
    C:\System Volume Information\_restore{10D2DF9A-CF24-4046-AF64-7A9F6B2D69AD}\RP300\A0135756.exe (PUP.Optional.OptimizerPro) -> Quarantined and deleted successfully.
    (end)
  10. Kitsune713
    Elizabeth23, Oct 1, 2014
  11. Kitsune713
    nanaviai
    What kind of malware? Trojan? browser hijacker? adware?
    nanaviai, May 3, 2017
  12. Kitsune713
    nanaviai
    Some antivirus can not detect browser hijacker or PUP once they are legitimate.
  13. Kitsune713
    nanaviai
