system very slow
Discussion in 'Windows XP Help and Support' started by maryph, May 26, 2013.
  1. maryph
    maryph
    Hello,
    My laptop is suddenly very slow and I get a Windows Script Host message (I've attached a screenshot of the message).
    Hopefuly someone knows what I can do.
    Thank you!
  2. maryph
    http://www.ehow.com/how_7306186_repair-windows-script-host.html
    to repair see above.
    also do the following to tell me something of your system and to ensure your system is clean:
    1. what is your current antivirus?
    2. Click Start, Run and in the box enter:
    msinfo32
    Remove all found, reboot, and run again until scans run clean, these can be removed afterwards if you so choose.
    post back with required info and results of scans.
    Elizabeth23, May 27, 2013
