Problems installing ms Office 2003 in MicroXP
Discussion in 'Windows XP Help and Support' started by panoss, Dec 30, 2014.
  1. panoss
    panoss
    I 've installed Micro XP and I 'm trying to install MS Office 2003.
    But during installation I get the error:
    "Error 1904. Setup cannot register module ...OFFICE11\1033\MSRCLR40.dll.
    blah blah blah..."
    I googled it but didn't find any solution.
    What can I do to fix this?
    Has anyone installed Office 2003 in Micro XP?
  2. panoss
    Elizabeth23, Dec 31, 2014
  3. panoss
    panoss
    That was the first I had done.
    It didn't help.
    panoss, Dec 31, 2014
  4. panoss
    https://onedrive.live.com/?cid=d7389b68b3a275ad&mkt=en-US
    go to my onedrive and download MDAC.inf, save to desktop, right click and choose properties to unblock file, then double click to install or right click and choose install.
    http://support.microsoft.com/kb/279223/en-us
    what service pack do you have installed on the micro xp??
    go to start, run and type in
    msiexec to find your version of installer
    it should be 4.5 as the latest installer.
    http://www.msfn.org/board/topic/663...e-programs/?hl=+reinstall++removed++languages
    have you read the above on what NOT to remove from xp
    also , please give the complete error message as there are lots of 1904 errors, thanks
  5. panoss
    panoss
    I did this but an error message appeared:
    'The file 'adcjavas.inc on Windows XP Proffesional Service Pack 3 is needed."
    SP3 .
    Windows ® Installer. V 4.5.6001.22159
  6. panoss
    panoss
    I tried to follow this 'Reinstalling MDAC in XP SP3' from here: ww w.technipages.com/reinstalling-mdac-in-xp-sp3 (remove space between 'w's)
    And I can't find mdac.inf in this directory (G:\WINDOWS\inf, G is my drive letter)
    Maybe I haven't installed mdac?
  7. panoss
    I have uploaded the file adcjavas.inc to my onedrive (above), you can download it.
    if you downloaded the .inf file then from your desktop move it to G:\windows\inf.
    You might be having problems since windows generally wants to be on C: but if you have run your os from there before, ??
    from here
    since you will not be able to reinstall try the above. I will check back for your results.
  8. panoss
  9. panoss
    panoss
    Fisrtly, happy new year everybody!
    Now...
    I didn't make it from my xp cd, I downloaded it.
    It's microXP by eXPerience.
    I downladed SP3 and took al the files needed from there (quite a lot).
    I also installed some extra files, about 20 (well, I suppose, I didn't count them) which I downloaded from dlldump and sites like this (I hope they have no virus...).
    Anyway, at the end an error message appeared: "windows cannot find g:\windows\system32\odbcconf".
    I made a diy odbcconf.chm (that's a help file, right?) and put it in g:\windows\system32\ but the same message appears.
    I guess it's not chm file, it's just 'odbcconf'.
    I tried to reinstall office 2003 and the initial error, (the one related to MSRCLR40.dll) again showed up.
    I guess I 'll have to give up.
    panoss, Jan 1, 2015
  10. panoss
    Have you ever used this os before??
    There are no legal downloads of xp except for the version provided by Microsoft and you need 6 floppy disks to install.
    I do know that you cannot delete the OBDC folder as that is needed for other parts of windows and as you have just experienced obviously MDAC is needed also,
    There are over 3500 files in sp3, I know that you want a micro xp, but have you thought of just downloading and installing the entire sp3??
    You can tell me if you need a few more files and I can upload them for you.
    Either Jose or Myself have lots of files already and you can browse through and see if there are more files already up for you to download.
    https://onedrive.live.com/?cid=EC673DF6F8DFEE84&id=EC673DF6F8DFEE84!109&authkey=!AEMs5lwt9Todokc
    Do you have an install cd original or oem??
    Elizabeth23, Jan 1, 2015
  11. panoss
    ALSO:
    From the readme on the experience website, even if you do not use outlook express in a real installation it can be disabled but you need this for other parts of windows
    from same site as above, so maybe 2007 will work but not 2003
    You might want to post in the above forum??
    Also, you might want to try OpenOffice.org as any office 2003 docs are compatible and openoffice is free
  12. panoss
    Elizabeth23, Feb 17, 2016
