Printer drivers for XP
Discussion in 'Windows XP Drivers' started by Kathy, May 13, 2017.
  1. Kathy
    Kathy
    Anyone know where I can find a driver for a Canon MG3660 printer to run on Windows XP - or if one even exists? I tried the Canon site and downloaded from there but it wouldn't work. Grrr - don't you just hate it when you don't get a CD with a purchase!! If you can help I would really appreciate your assistance - thanks.
    Kathy, May 13, 2017
  2. Kathy
    Elizabeth23, May 13, 2017
  3. Kathy
    Kathy
    I have no idea whether PC is 32 or 64, but will check out the links you sent me. They are not the one I downloaded, so hopefully this will be able to fix my problem. Will let you know when I have had time to try it. Thanks for the help.
    Kathy, May 14, 2017
  4. Kathy
    Kathy
    To Elizabeth23, That download link you sent me worked brilliantly. Thank you so very much, you have been a really big help to me. Hope you have a great day.
    Kathy, May 14, 2017
  5. Kathy
    great work and to see if you are 64 or 32, go to start, right click on My computer, choose properties, and choose general tab, if you do not see 64 anywhere on that page then you are 32bit, :)
    Elizabeth23, May 14, 2017
  6. Kathy
    Kathy
    Great - now I know it must be 32 bit. Sooooo helpful! Very glad I found this great site and the fellow XP users.
    Kathy, May 14, 2017
