Not able to transfer files from Android 6.0 Marshmallow into pc
Discussion in 'Windows XP Drivers' started by Nil, Aug 31, 2018.
  1. Nil
    Nil
    When I connect my Android to the pc,the pc show only windows media player to take action.The folder of the Android also not appearing in the my computer section.
    I am not able transfer files with windows media player .
    Please help me.
    Nil, Aug 31, 2018
  2. Nil
    Elizabeth23, Aug 31, 2018
  3. Nil
    Nil
    Nil, Sep 1, 2018
  4. Nil
    Lockherup
    Look on your phone for a menu, it should give you 3-4 choices, charge only, MTP, mount as a drive..
    select mount as a drive.
    Lockherup, Sep 5, 2018
  5. Nil
    Nil
    No option for mount as a drive
    Nil, Sep 5, 2018
  6. Nil
    Lockherup
    Well that sucks. there are some cases where the vendor disables these options. Why don't you see what other people are saying about your model phone and there may a workaround.
    Lockherup, Sep 8, 2018
