no sound
Discussion in 'Windows XP Help and Support' started by SWANSTONSALLY, Mar 21, 2013.
  1. SWANSTONSALLY
    SWANSTONSALLY
    i have a used pc, windows xp, and there is no sound at all. im new to all this. please help:confused:
  2. SWANSTONSALLY
    msinfo32
    also while in this box, expand components on left by clicking the plus sign, then highlight Sound device and copy that info also.
    then I can look on line for your driver as you need to install it.
    Elizabeth23, Mar 21, 2013
