No Audio device found. VIA realtek
Discussion in 'Windows XP Hardware' started by Nemtrex, Nov 15, 2014.
  1. Nemtrex
    Nemtrex
    After my friend borrowed my PC i can't get my sound to work. this is the second week im trying to fix it, and i got it fixed once. But after a reboot it says no audio device found...
  2. Nemtrex
    need the make, model and model number of the pc
    Elizabeth23, Nov 15, 2014
  3. Nemtrex
    Also: check to see if the windows audio service is set to automatic
  4. Nemtrex
    Nemtrex
    How do i find this information? I know i can use an search engine, but i have already tried for 2 weeks? i never had problems with my pc that i can't solve but this is so enoying and i cant find any results on google either..
  5. Nemtrex
    Nemtrex
    I also recieved an bluescreen error when i tried to install the drivers..
  6. Nemtrex
    msinfo32
    above will give me the info I need on make, model and model number
    to check your services, go to start>run> type in services.msc, and scroll down to windows audio , double click on it and the properties window will open and then you can select automatic and start the service, if it is not already selected. Let me know if the service was already selected.
    if you did not install the proper drivers, you might get a blue screen, I will need the stop numbers of the blue screen and any files and or program listed in the blue screen.
  7. Nemtrex
    Nemtrex
    OS Name Microsoft Windows XP Professional
    Version 5.1.2600 Service Pack 3 Build 2600
    OS Manufacturer Microsoft Corporation
    System Name DICKSIZE27
    System Manufacturer Packard Bell BV
    System Model iXtreme J2869
    System Type X86-based PC
    Processor x86 Family 6 Model 15 Stepping 2 GenuineIntel ~2128 Mhz
    BIOS Version/Date Phoenix Technologies, LTD W7301VP2.308, 2007-02-05
    SMBIOS Version 2.4
    Windows Directory C:\WINDOWS
    System Directory C:\WINDOWS\system32
    Boot Device \Device\HarddiskVolume1
    Locale Sweden
    Hardware Abstraction Layer Version = "5.1.2600.5687 (xpsp_sp3_qfe.080930-1426)"
    User Name DICKSIZE27\DickSize33
    Time Zone W. Europe Standard Time
    Total Physical Memory 4*096,00 MB
    Available Physical Memory 2,06 GB
    Total Virtual Memory 2,00 GB
    Available Virtual Memory 1,96 GB
    Page File Space 4,78 GB
    Page File C:\pagefile.sys
  8. Nemtrex
    Nemtrex
    need 5 post count to post images...........
  9. Nemtrex
    Nemtrex
  10. Nemtrex
    http://www.packardbell.com/pb/en/GB/content/download
    go to the above site and enter your snid number to get the drivers for your pc, that way you know you will have the correct audio driver.
    you can also do a system restore to a point before the error began occurring.
  11. Nemtrex
    checking that stop code, be right back
  12. Nemtrex
    From what I have read this is a bad component error
    did you do a system restore?
    have you run scans with your antivirus??
    from here
    EDIT:
    you should uninstall the sound driver and then reboot and then install the correct driver that you would get from the manufacturer's site in my previous reply
  13. Nemtrex
    Nemtrex
    And how do i find my SNID? my pc is home built with different parts i think
  14. Nemtrex
  15. Nemtrex
    Nemtrex
    graphic card and my ram memorys is only what is changed i think.. it was my friend who changed it but it worked when he had the pc.. i cant find my model on the website either...
  16. Nemtrex
    do you have either of these numbers
    Elizabeth23, Nov 16, 2014
  17. Nemtrex
    #17
  18. Nemtrex
    billy gates
    another area to check is .. if you have a video/sound card installed.. this means there are 'two' areas of where to plug in the green end of the mindjack the other being the main motherboard .., .. I have found myself many times of where I have removed the wiring to transport the box .. then plugged in the minijack to the wrong audio input ..
    easy to do easy to check and easy to fix ...
    billy gates, Dec 12, 2014
    #18
