"My Pictures" screen saver no longer works
Discussion in 'Windows XP Help and Support' started by cocoa3c, Aug 2, 2013.
  1. cocoa3c
    cocoa3c
    Hi! I'm using an Acer netbook running XP...its about four years old and works really well. I noticed a short while ago when my screen saver came on, it was no longer showing my photos. I have it on the "My Pictures" screen saver. It shows only a black screen with an explanation that there are no photos in the folder I have it set to. So, I redid the settings and it doesn't matter what folder I set it to, it says there are no photos in it. What happened? Can I fix it to work again? I don't know what may have changed.
    The other preset screen savers work, just not "my pictures".
    Thanks for any help you have to offer.
    God Bless
  2. cocoa3c
    did you look in My pictures, and are your photos still in there?
    Have you installed any new programs?
    have you run some scans?
    please do the following and also tell me what your current is your current antivirus:
    msinfo32
    http://support.microsoft.com/kb/326719
    above is ok if there are more than one user on your pc
    http://support.microsoft.com/kb/310353
    use method 2 and do a clean boot, see if screensaver will run, if it does then a third party program is preventing, and you will have to disable one at a time to find out which is the guilty party.
    Post back after the above troubleshooting steps, oh, and one more question, are you fully updated and patched at Microsoft updates?
    Elizabeth23, Aug 3, 2013
