Mbamservice.exe (MBAM) using too much ram!!
Discussion in 'Windows XP Help and Support' started by JohnDohe, Mar 5, 2015.
  1. JohnDohe
    JohnDohe
    I'm using virtual XP (VXP) on a Windows 7 machine.
    Malwarebytes mbamservice.exe is using over 220,000K of memory as shown
    in Task Manager (TM).
    CPU usage is 0-8%.
    The following MBAM Advanced Settings are unchecked:
    "Start Malwarebytes Anti-Malware with Windows"
    "Enable self-protection module"
    "Reduce priority of scans to improve multitasking"
    MSCONFIG has MBAMService unchecked.
    Questions:
    1. Why is Mbamservice.exe using so much memory?
    2. Is this normal?
    3. If I've unchecked all that I've noted above, why is Mbamservice.exe still loading?
    4. How do I reduce the amount of memory Mbamservice.exe is using?
    5. How can I keep it from loading upon Windows starting up?
    6. Any other suggestions?
    Oh yes,
    HALP !!! :eek:
    John
  2. JohnDohe
    Elizabeth23, Mar 5, 2015
