Malware protection questions
Discussion in 'Windows XP Help and Support' started by nopeda, Jan 30, 2013.
  1. nopeda
    nopeda
    I'm using dial up and that's slow enough to begin with, but the malware/addware
    or whatever it's really called slows things to the extreme. I've got Spybot and
    run that now and then, but it doesn't seem to matter because those programs get
    back in pretty quickly and some of them it seems as soon as I log on. Is there a
    way to keep them out altogether that won't slow the computer way down? I've
    gotten the impression that some defense programs slow things down more than the
    viruses do...
  2. nopeda
    first off spybot is only spyware, you need one antivirus running in real time before you should even connect to the internet,
    I will give you a link to Bleeping computers and you can go there to see if the infections can be removed from your pc.
    if the infections are entrenched it might just be better to do a clean reinstall.
    Malware removal sites courtesy of LemP
    Or -- and I think this is what you really should do because your problem is likely to be buried pretty deeply -- seek guided malware removal help from one of the specialty forums:
    • Bleeping Computer: Am I infected? What do I do?
    http://www.bleepingcomputer.com/forums/forum103.html
    • MalwareBytes' Anti-Malware
    http://forums.malwarebytes.org/index.php?showforum=41
    • SpywareHammer: Malware Removal
    http://spywarehammer.com/simplemachinesforum/index.php?board=10.0
    • Spyware Warrior: Help with spyware removal
    http://www.spywarewarrior.com/viewforum.php?f=5
    • DSL Reports: Security Cleanup
    http://www.dslreports.com/forum/cleanup
    • Bluetack: Malware Removal
    http://www.bluetack.co.uk/forums/index.php?showforum=172
    http://www.microsoft.com/en-us/download/details.aspx?id=5201
    MSE Download
    http://experts.windows.com/w/experts_wiki/89.aspx
    MSE installation checklist
    if you install MSE, then read checklist thoroughly.
    Elizabeth23, Jan 30, 2013
