lsass.exe - System Error ( An invalid parameter was passed to a service or function )
Discussion in 'Windows XP Help and Support' started by Agonche, Jan 18, 2015.
  1. Agonche
    Agonche
    My Windows XP machine won't boot.
    After Windows XP loading bar, it displays this message:
    HELP :)
    Thanks in advance.
  2. Agonche
    Courtesy of Jose Ibarra
    http://www.imgburn.com/
    cmd
    chkdsk c: /r
    above from here, read the replies thoroughly, but run the chkdsk first, at least twice.
    Elizabeth23, Jan 18, 2015
  3. Agonche
    Agonche
    @Elizabeth23
    Thanks for the long and detailed reply.
    What I did was I created a live Linux USB drive. Booted on linux and copied the data that I needed from the C:/ (system) drive to the D:/ drive.
    Then I did a fresh install of Windows XP.
    I did all this before you posted a reply, I thought there is no solution. This may work for someone else though.
    Agonche, Jan 19, 2015
  4. Agonche
    Thanks for the update. :)
    Elizabeth23, Jan 20, 2015
