Internet browsing problems
Discussion in 'Windows XP Networking' started by Bobify, May 1, 2019.
  1. Bobify
    Bobify
    I have reinstalled windows xp on my old laptop everything is fine except I cannot browse the internet my WiFi connection says its strong and sending and receiving but when I try and browse it keeps saying it carnt connect to any site this is on internet explorer and Firefox any ideas please
    Bobify, May 1, 2019
  2. Bobify
    Hatboro
    Bobify; You are saying you can't connect via wifi? Can you reach the
    Internet via a LAN / hard wired connection. You're running with two
    browsers, both MS-IE and Firefox. Their recent / current versions don't
    support Windows XP. Are you using their older versions that do support
    XP?
    Do you have another device that reaches Internet content via your router &
    modem or (gateway; that provides both modem and router functions) that your
    laptop is connected to?
    If you post here again, consider providing details about the laptop....mfgr,
    model #, what XP version, your Internet provider, your gateway or your
    separate modem and router details.
    Within the past week, I had to return my gateway to Comcast for
    another one; the one I'd been using stopped working via wifi.
    Hatboro, May 15, 2019
    cmccaff1 likes this.
  3. Bobify
    Chloezer
    Tennessee
    My net connection is on, but can not open internet on my pc. Pls help
    Chloezer, Aug 9, 2019
  4. Bobify
    look in device manager, are you missing any drivers, it will show up as a yellow exclamation point, and if you see some there, I will need the make, model, and model number of your pc to see if I can find a driver.
    Elizabeth23, Aug 10, 2019
    Chloezer likes this.
  5. Bobify
    Chloezer
    Tennessee
    thank you!
    Chloezer, Aug 10, 2019
  6. Bobify
    Computer semi-expert
    State of Confusion
    Chloezer: next time create a new thread for your problem.
    Computer semi-expert, Aug 10, 2019
  7. Bobify
    Dyehard
    Resurrected an old IBM G40 laptop after years on the shelf under a foot of dust. Firefox updated itself several times and finally displayed a message box saying future versions of FF didn´t support XP. The o/s installed a bunch of updates. No problems with internet access. I´ve had the same WIFI router for years that was installed way back when XP ruled the roost. Maybe some of the new routers do not work well with XP.
    Dyehard, Aug 18, 2019
  8. Bobify
    Dyehard
    It´s not surprising that some of the brand spanking new WIFI routers & related hardware do NOT have XP drivers. Those of us XP dyehards running older hardware are still good to go. Many of the well known hardware manufacturers had bailed within a year after XPs official demise in 2014. Software mfgs too. Now I´m getting the odd nag notice about my 2007 Microsoft Office suite having retired. If you think it´s a conspiracy to squeeze the consumers wallet as hard and often as they will tolerate you´ve hit the nail on the head. It´s certainly NOT about a deep rooted concern for our cyber-security. Boils down to good ole GREED.
    Dyehard, Aug 20, 2019
