innet scs si-50083
Discussion in 'Windows XP Drivers' started by roland, Aug 15, 2015.
  1. roland
    roland
    Hello,
    Could anyone help me to get the driver for theInNet scs si50083 ethernet adapter ? It is on an old compaq EVO wich i got from a friend.
    I needed to reinstall windows on it and since then it cannot find the right driver. I already tried the HP site, without succes. If anyone could help it would be great
    Roland
  2. roland
    https://www.google.com/#q=the+InNet+scs+si+50083+ethernet+adapter
    above search page has lots of hits for this driver, however, any driver needed for an hp product is available on their site:
    http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=97106&swLangOid=8&swEnvOid=1098
    3 network drivers are listed above
    you might need to further filter the choices, above are for xp home
    msinfo32
    ALSO : go to components in above window and click on plus sign then click on the plus sign on Network, highlight adapter and post that info here also
    Elizabeth23, Aug 15, 2015
Similar Threads
There are no similar threads yet.
