ICE Virus trouble getting safe mode
Discussion in 'Windows XP Help and Support' started by Dhook01, Apr 17, 2014.
  1. Dhook01
    Dhook01
    Hey - just got the ICE virus; ransomware.
    So I've seen the fix for it but when I try to restart in safe mode my PC auto restarts. I know I can use the prevent auto restart but how do I also get the system in safe mode?
    Any help is appreciated, needing this PC back up an running quick have some work to do tonight.
  2. Dhook01
    first came upon this thread and it lead to this article.
    you can burn a cd with Hiren's boot cd and use the mini xp portion to get your data off and then reinstall your os. burn from a working clean pc.
    Courtesy of Jose Ibarra
    http://www.imgburn.com/
    cmd
    chkdsk c: /r
    and you may have to run fixmbr or fixboot from the recovery console also:
    http://commandwindows.com/recovery.htm
    Recovery Console Commands (using SET also)
    http://www.remotelan.net/tutorials/ms-dos/top_10.php
    Recovery console commands.
    Elizabeth23, Apr 18, 2014
