I need an android MTP driver for XP
Discussion in 'Windows XP Drivers' started by WindowsXPforever, Jun 22, 2018.
  1. WindowsXPforever
    WindowsXPforever
    Well i have, a huawei y3 and when i install the mtp driver from, microsoft and wmp 11 it still doesnt work, ! If so i really dont like, wmp 11 i like wmp 9 .sooo why it still doesnt work
  2. WindowsXPforever
    Elizabeth23, Jun 22, 2018
  3. WindowsXPforever
    WindowsXPforever
    WindowsXPforever, Jun 23, 2018
  4. WindowsXPforever
    WindowsXPforever
    WindowsXPforever, Jun 24, 2018
  5. WindowsXPforever
    are you getting specific errors and if so what does it say exactly, and are there any errors in event viewer specific to this issue, if so paste a copy of the error here so I can view it.
    Elizabeth23, Jun 24, 2018
  6. WindowsXPforever
    WindowsXPforever
    It want to install a driver but i already installed when i plug in it
  7. WindowsXPforever
    in other words, the plugin installed the driver, but windows is not excepting the driver?
    go to device manager and uninstall the driver then shutdown, plug in device, then restart computer. the driver should install properly unless it is not compatible with xp.
  8. WindowsXPforever
    WindowsXPforever
    It sees the device but it still says found new hardware mtp and the new hardware wizard popups
  9. WindowsXPforever
  10. WindowsXPforever
    WindowsXPforever
  11. WindowsXPforever
    yes, and the question?
  12. WindowsXPforever
    WindowsXPforever
    It means that its the exacte model
  13. WindowsXPforever
    the link I provided is for that model??
  14. WindowsXPforever
    WindowsXPforever
    Oh my Failed to installl :(
    WindowsXPforever, Jun 25, 2018
  15. WindowsXPforever
    Elizabeth23, Jun 25, 2018
  16. WindowsXPforever
    cleverscreenname
    As far as I know, phone drivers are model-specific but MTP is a transfer protocol like ADB. So perhaps he isn't looking for a USB phone driver. I'm getting lots of search results for "xp mtp driver" but I don't currently have time to read them.
    cleverscreenname, Dec 2, 2023
