I need a video driver and an audio driver for my xp pc
Discussion in 'Windows XP Drivers' started by WindowsXPforever, Jul 15, 2018.
  1. WindowsXPforever
    WindowsXPforever
    i cant find them :(
  2. WindowsXPforever
    WindowsXPforever
    So will you help me or what,? :(
    WindowsXPforever, Jul 18, 2018
  3. WindowsXPforever
    How To Find Drivers For An Unrecognized Device
    1. Open Device Manager (Control Panel>System>Hardware>Device Manager)
    2. The hardware whose drivers are missing will appear as Unknown device, so it's easier to locate the device.
    3. Right click on the unknown device and click on Properties.
    4. Under the Properties window click on Details tab and select Device Instance Id from the drop down box.
    5. You should see a code similar to this
    PCI\VEN_8086&DEV_27DC&SUBSYS_30868086
    &REV_01\4&1E46F438&0&40F0
    6. The portion of the code highlighted in RED is the Vendor ID and the portion highlighted in GREEN is the Device ID. In this example:
    Vendor ID = 8086
    Device ID = 27DC
    7. Once you have obtained both the IDs, proceed to
    https://www.pcilookup.com/
    There you can either search for the vendor from the vendor ID or directly get information about the device along with the vendor name by searching with the device ID.
    Elizabeth23, Jul 19, 2018
    WindowsXPforever likes this.
  4. WindowsXPforever
    WindowsXPforever
    Thank you i found them :)
    WindowsXPforever, Jul 19, 2018
  5. WindowsXPforever
    okey dokey
