I Can't See Any Deleted Files in Recycle Bin - HELP!
Discussion in 'Windows XP General Discussion' started by koolx, Nov 21, 2014.
  1. koolx
    koolx
    I can't see any deleted files in Recycle Bin. It's very strange. How can I fix this?
    koolx, Nov 21, 2014
  2. koolx
    Right-click on the recycle bin and check the options. If bypass recycle bin is checked, uncheck it.
    also if you use defraggler it gives you the option to empty the recycle bin when you run it, also if you use ccleaner, see if the recycle box is checked.
    Elizabeth23, Nov 21, 2014
  3. koolx
    koolx
    Hi Liz. I got the problem resolved through a command. Sorry for the bother.
    koolx, Nov 21, 2014
  4. koolx
    no problemo
