How to circumvent 'SysKey' system password block
Discussion in 'Windows XP Help and Support' started by john boscoe eames, Apr 24, 2015.
  1. john boscoe eames
    john boscoe eames
    Anyone know how to circumvent 'SysKey' system password block?
    John
  2. john boscoe eames
    Elizabeth23, Apr 25, 2015
  3. john boscoe eames
    john boscoe eames
    John Boscoe Eames - SysKey Scam
    Hi Elizabeth
    Thanks for your response. I Should have made it clear; can't get to the Start position,
    Computer is blocked as soon as I switch it on. Scammed by a telephone call from an Asian sounding guy, took control and corrupted the PC (Old Dell using Windows XP) when I wouldn't pay $300.
    John
    john boscoe eames, Apr 27, 2015
  4. john boscoe eames
    have you tried a Hiren's boot cd to see if you can access your drive, to get your data off and then you can reinstall xp??
    Why don't you see if you can restore your computer to two (or three) days ago prior to the incident.
    If you can't login, see if you can boot in Safe Mode with Command Prompt and if you can get to a Command Prompt, you can run your XP System Restore from there by entering this command:
    %SystemRoot%\system32\restore\rstrui.exe
    Choose a date prior to the incident and keep your fingers and toes crossed.
    above is from here
    read all replies from A. User.
    if that thread does not help, then read from this search page
    let me know if you still need help afterwards.
    Elizabeth23, Apr 28, 2015
  5. john boscoe eames
    john boscoe eames
    Hi Elizabeth
    I've tried your suggestions, but no matter what I click it still comes back to
    Windows XP Password Request. Anything else I can try?
    John
    john boscoe eames, Apr 28, 2015
  6. john boscoe eames
    Elizabeth23, Apr 29, 2015
  7. john boscoe eames
    john boscoe eames
    What is a Hiren's Boot and how do I re-install Windows XP on my old Dell?
    John
    john boscoe eames, Apr 29, 2015
  8. john boscoe eames
    Courtesy of Jose Ibarra
    http://www.imgburn.com/
    cmd
    chkdsk c: /r
    http://pcsupport.about.com/od/operatingsystems/ss/instxpclean1.htm
    With pictures of clean install
    http://windows.microsoft.com/en-US/windows-xp/help/setup/install-windows-xp
    http://www.windowsxphome.windowsreinstall.com/sp2installxpcdoldhdd/indexfullpage.htm
    http://www.blackviper.com/os-install-guides/windows-xp-professional-install-guide/
    http://tweakhound.com/xp/installxp/installXP1.htm
    Clean installs of XP sites
    make sure you have the drivers downloaded to a flash drive to install after installing the os, and windows updates will not work without sp3, so you will have to download that and you could slipstream it into your install cd.
    what is the make, model and model number of your dell?
  9. john boscoe eames
    john boscoe eames
    Many thanks for your help. Will try all.
    John B E.
    john boscoe eames, Apr 30, 2015
  10. john boscoe eames
    okay will check back, :)
    Elizabeth23, May 1, 2015
  11. john boscoe eames
    john boscoe eames
    Tried everything now to unblock 'Syskey' scam, but no good; thanks anyway. So how do I
    re-install Windows XP from scratch on my old Dell Dimension 2400?
    John B E.
    john boscoe eames, May 2, 2015
  12. john boscoe eames
    follow the steps in the links of my last reply on reinstalling xp
    go to the dell website, insert your service tag and download all the necessary drivers
    go to the microsoft download center and download sp3
    set the bios to boot from the cd drive first, and start your installation
    do a full format , not a quick format
    once os is installed install the dell drivers in a certain order:
    http://www.dell.com/support/article/us/en/19/SLN148687/EN
    http://www.dell.com/support/Article/us/en/19/SLN155406/EN
    above is a link on reinstalling on a dell
    http://www.dell.com/support/article/us/en/19/SLN151785/en
    above is a link on how to get your dell drivers
    let me know if you have further questions
    Elizabeth23, May 3, 2015
  13. john boscoe eames
    john boscoe eames
    Dell Dimension 2400
    John
    john boscoe eames, May 3, 2015
  14. john boscoe eames
    john boscoe eames
    Elizabeth
    I am getting lots of suggestions how to free my PC from a 'syskey' block but they are all assuming that I can get to the 'Start' position. I CAN'T! Everything I try results in the Syskey Password demand which of course I don't know. Can I assume that there is NO
    way round this problem?
    John
    john boscoe eames, May 4, 2015
  15. john boscoe eames
    john boscoe eames
    How do I get to the 'Start' position when I am blocked by a 'Syskey' password demand on my old Dell Dimension 2400 working on Windows XP? Help!
    JBE
  16. john boscoe eames
    I thought you had wanted to reinstall the os???
    from here
    Elizabeth23, May 5, 2015
