how to change volume of system sounds?
Discussion in 'Windows XP Help and Support' started by LCD336, Feb 27, 2015.
  1. LCD336
    LCD336
    I want to decrease the volume of the system sounds without decreasing the volume All together. I copied my laptops(win 7) sounds[.wav] and put them on my desktop(XP) and i got the sounds the way i like them. but theyre kinda loud sometimes.
  2. LCD336
    Elizabeth23, Feb 27, 2015
  3. LCD336
    LCD336
    I wanna change the system sounds volumes because sometimes it can be a bit loud, i wanna change its volume so the system sounds are a little quieter, like what windows 7 did.
  4. LCD336
    http://windows.microsoft.com/en-US/windows-xp/help/setup/change-windows-xp-sounds
    okay from what I can understand, is you have your .wav sounds from win 7
    put them on the desktop for now in a folder
    now from one of the other links in my last reply there was a way to adjust volume of INPUT sound, so adjust the volume of the sounds in the folder and THEN install them and save them as your own win7 sound theme in sounds.
    ?? sound feasible??
    did you use the below tutorial to install the win7 sounds??
    http://www.askvg.com/transform-windows-xp-into-windows-7-without-using-customization-pack/
  5. LCD336
    LCD336
    Like, i want to have my master volume to be high, but i don't want my system sounds to be THAT loud also
    LCD336, Mar 2, 2015
  6. LCD336
    do not think it is possible with xp, but will keep searching.
    from here
    Elizabeth23, Mar 2, 2015
  7. LCD336
    LCD336
    :) ok. thank you.
    LCD336, Mar 2, 2015
