How Do I Hack My Internet Speed?
Discussion in 'Windows XP Help and Support' started by koolx, Aug 26, 2014.
  1. koolx
    koolx
    koolx, Aug 26, 2014
  2. koolx
    https://www.google.com/#q=does+xp+need+internet+optimization&spell=1
    did you go to google search page on optimizing xp ??
    http://forum.notebookreview.com/windows-os-software/56641-cable-nut.html
    read the thread here on cablenut, it is a pretty old program, some reviews say it does not work on xp, and the thread above says that xp has already optimized the settings.
    I have tweaked my xp, but not the internet, it seems fast enough to me, I have done some speed tests, with and without my ISP provider on the phone, and they say it is pretty good.
    I have tried to see if downloads would be faster, but this is not necessarily an xp tweak as the download speed depends on where you are downloading from.
    I did read through your link, I have set the registry settings and disabled the sections advised on network properties, but I will not download cablenut. It seemed very technical to me. But if you try it remember to set a restore point. :)
    Elizabeth23, Aug 26, 2014
  3. koolx
    koolx
    Thanks Liz. I think I'll go ahead and just set the registry tweaks and leave out cablenut. Thanks!
    koolx, Aug 27, 2014
  4. koolx
    You are welcome. :)
    Elizabeth23, Aug 27, 2014
