Hard Drive
Discussion in 'Windows XP Hardware' started by mlum, Jan 19, 2013.
  1. mlum
    mlum
    My Hard Drive crash so I installed it in another computer so I could retrieve my photos and Document files but the computer doesn't recognize the drive. What do I do now?
    mlum, Jan 19, 2013
  2. mlum
    burn a copy of Hiren's boot cd get your data off the drive, then take harddrive to be tested.
    Courtesy of Jose Ibarra:
    http://www.hirensbootcd.org/download/ (look near the bottom of the page, do not click on any ads).
    http://rufus.akeo.ie/
    http://www.hiren.info/pages/bootcd-on-usb-disk
    Hiren’s for flash drive
    Elizabeth23, Jan 21, 2013
