Error loading operating system
Discussion in 'Windows XP Help and Support' started by jameshcleong, Nov 20, 2014.
  1. jameshcleong
    jameshcleong
    Hello,
    I am using Windows XP and have, several times, encountered a blue screen problem. Attached herewith are two of such blue screens that I have encountered.
    The common thing that occurred after these two (and the other) blue screen problems is an
    'Error loading operating system' message after I reboot my PC.
    Please advise on the possible causes of this problem and how I may conclusively fix it.
    Thank you.
  2. jameshcleong
    http://www.bleepingcomputer.com/forums/t/122617/win32ksys-bsod/
    according to above link this error is mostly caused by memory
    below are links to download memtest86+ and imgburn, you will want to create a bootable cd with imgburn of the memtest86+ iso image.
    http://www.memtest.org/#downiso you want the .zip file
    http://www.imgburn.com/index.php?act=download
    insure that you read each page of the installation so that you do not install any unwanted extra softwares.
    http://www.geekstogo.com/forum/topic/246994-guide-to-using-memtest86/
    above is a tutorial on using memtest86+, you might want to print.
    Elizabeth23, Nov 20, 2014
